Hello,
I'm currently building a enthusiast build in the $3000 price range and now my friend wants to join in the fun and build one for himself. He is looking for something more in the $1500 price range. He has all peripherals so this budget is just for the cpu. When looking at top of the line stuff figuring out what parts are best is pretty cut and dry, but there are a lot more options when going into the $1500 price range on what parts to use. I would love some suggestions on builds that I could recommend to him.
Thanks.
https://linustechtips.com/topic/1110981-suggestions-on-build-for-a-friend/
I think you mean PC? Unless he's shooting for a Xeon platinum
Here's a part list if your intended budget was for USD
If you want to get below that $1500 point, drop the SSD to 512GB
Primary PC:
5 minutes ago, Drovic said:
Thanks for the suggestion. Yes, that was bad typing I meant PC.
He is Canadian, but I'm shopping around $1500 USD factoring in that it will be more in Canadian.
I also see there is no cooling in the build you provided?
be sure to quote people so that we see your responses.
The CPU has a decent stock cooler so that would be fine to keep, feel free to buy something fancier if you feel like it.
Make sure you use the appropriate regional currency for your topic, or else we will make the wrong parts choices. This list is way better in the Canadian market.
Primary PC:
38 minutes ago, Fasauceome said:
Well, you are paying 116 cad for less than CX quality, and that's when RMx 550 is $110...
I think it's the cheapest B+ or higher that's full modular, so I went with it, not taht it would hurt to go for CXM or something. Also 650 for quieter fan, also not necessary.
Primary PC:
20 minutes ago, Drovic said:
I believe he is using a 120 hz monitor and it's just a general gaming machine. He would like to keep it around 1700-1800 Canadian.
Something like this would do fine. The RX 5700 XT is good for 1080p/1440p. An R5 3600 is good value for gaming.
PCPartPicker Part List
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  ($260.50 @ Vuugo)
CPU Cooler: ARCTIC Freezer 34 eSports DUO CPU Cooler  ($59.85 @ Amazon Canada)
Motherboard: MSI B450 TOMAHAWK MAX ATX AM4 Motherboard  ($154.99 @ Memory Express)
Memory: Team T-FORCE VULCAN Z 16 GB (2 x 8 GB) DDR4-3000 Memory  ($83.99 @ Newegg Canada)
Storage: Intel 660p Series 1.02 TB M.2-2280 NVME Solid State Drive  ($129.95 @ Vuugo)
Video Card: Gigabyte Radeon RX 5700 XT 8 GB GAMING OC Video Card  ($549.00 @ Powertop)
Case: Cooler Master MasterBox MB511 RGB ATX Mid Tower Case  ($121.99 @ Amazon Canada)
Power Supply: Corsair TXM Gold 550 W 80+ Gold Certified Semi-modular ATX Power Supply  ($99.99 @ Amazon Canada)
Total: $1460.26
Generated by PCPartPicker 2019-10-05 17:05 EDT-0400
12 minutes ago, LukeSavenije said:
cxm would hurt
cx wouldn't
o i forgot that CXM wasn't in B+
Primary PC:
Total: $1460.26
This is what I came up with. Let me know your thoughts.
What are your thoughts on this?
Not really that much more performance, but you are paying an extra $400 for it.
The RX 5700 XT isn't that far behind the 2070 Super. Slower in some games but faster in others. Not worth an extra $150.
The R5 3600 is better value than the R5 3600X although I believe that AMD are doing a free game thing so you would have to look at that.
That cooler is overkill. And a B450 board is plenty for a 6 core. You can still run an 8 core on the Tomahawk and a 12 core at a push with some additional VRM airflow.
Airflow with that case isn't very good.
Just now, lee32uk said:
Re the free game with the R5 3600X:
https://www.amd.com/en/gaming/raise-the-game
Thanks for the information. He wants a 2070 super which is kind of why I put that in there. Also the free game pretty much offsets the price difference as you showed on the 3600 vs. 3600x. I could swap the motherboard out for a b450 and save $80 or so. As for cooling an air cooler will be fine, but I think he wants an aio. I'd probably go with a dark rock pro, but that's kind of up to him.
You get a free game with the 5700XT as well (I did an edit above). Of course if he wants to pay extra for the 2070 Super then of course that is his decision.
Same goes for the cooler. I would rather have a 3700X and stock cooler for example over a 3600X and $120 AIO. Again it is his call ?
So if he gets the 3700x you don't think there is a need for any other cooler besides the one it comes with?
The stock cooler is decent enough. Obviously an aftermarket one would be better. But for the same overall price I would take a 3700X and stock cooler over a 3600X and AIO as you would be getting an extra 2 cores/4 threads with the 3700X. It will last a bit longer before needing an upgrade over the 3600X.
