Will it fit and flow?
Solved by TempestCatto,
For the weary internet traveler: I settled on using the Wraith Prism cooler that came with my 2700x (as I used a different cooler for the 2700x). It sits flush with motherboard like I need, will fit in a 3U chassis, and cools the cpu and vrms very well. Keeps the FX 8320 at 50C with a 4.2GHz overclock (not sure on voltage tho).
UPDATE: I'm at 4.4Ghz at 1.36 volts around 50C in Aida64, ambient room temp 23C. I swapped mobos for an MSI 990FXa after replacing the thermal pads on the VRM's. I could push it further, but meh. It's stable and I'm happy :3
