360 radiator and 4 fans
Solved by Skiiwee29,
Yes, you can setup all fans to be exhaust, which would cause Negative pressure in the system, and could potentially lead to more dust intake through the cracks and crevices of the case. Not all cases work well in this scenario though so testing all types of fan configurations is the best option to find out what works best for you. My recommendation would be to have the front as intake, rear and top as exhaust to allow your GPU fresh air supply to keep it fed as well. But again, testing it in your scenario is the best option to keep flipping, twisting, turning to find out the optimal configuration for you and what you get out of it.
