Guys, I have several 5v ARGB products on my mobo running perfectly. No AURA Sync problems at all. I want to change my case to Cooler Master H500P and it has 2x 200m 12v RGB fans at the front. Naturally, I'll connect them to the 12V RGB header
Will the MOBO be able to run both RGB and ARGB at the same time? Will AURA Sync be confused by having to mix the two?
2x MF200R RGB RGB 12v fans at the front, 4x MF120R ARGB 5v inside the case. P.s: I have a cooler master controller go with ML360R, can i use it to sync both RGB and ARGB ?
Thanks
https://linustechtips.com/topic/1110140-mixing-rgb-and-argb-on-crosshair-vii/
