What do you want the computer to do? Kind of hard to recommend you something based on nothing.
Do your needs only warrant a Celeron?
Do your needs warrant an EYPC 7742?
Need a little more information.
You're missing so much information.
And you posted in the wrong section.
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
I was about to reply he had mentioned that, but then realised he means a CA$ 1K PC, not a US$ 1K PC for doing CAD ?‍♂️
F@H
GPD Win 2
Read this:
Moved to New Builds and Planning.
Make sure to quote a post or tag a member when replying or else they won't get a notification that you replied to them.
1 minute ago, LHG said:
Mainly for gaming
okay, also what is the performance you are looking for 1440p on high/ultra or 1080p Ultra ? and what games are you most looking forward to playing. People will then be able to give you some recommendations on parts that will be most useful to you :)
7 minutes ago, LHG said:
It's my first build so 1440p on high
I saw a separate post from you looking for some info on a Ryzen build, really with the one the guy posted, though its good you might want to spend a bit extra to get a faster GPU, a 2060 / 2060 super would be the sweet spot for Nvidia imo. For AMD, their card is quite impressive for its cost so either a 5700XT or 5700 would do you well. If you don't care for 144Hz a 1650 or 1660 would be just sufficient
Ryzen is affordable to run for CPU's but you really want fast ram for it to run as optimally as possible (3000 - 3200MHz) Corsair Vengance LPX ram is a good mid ground choice, but it is missing the RGB. Ryzen also comes with a decent cooler that will work for your needs.
After the CPU and GPU, the rest of the build should really just be based on your needs/ cares. Example: if you care for fast storage get a board with NVMe, if you need high storage space either get an SATA SSD or a Spindle Drive... Etc.
PCPartPicker Part List
CPU: AMD Ryzen 5 2600 3.4 GHz 6-Core Processor  ($164.99 @ Memory Express)
Motherboard: ASRock B450M Pro4-F Micro ATX AM4 Motherboard  ($82.50 @ Vuugo)
Memory: Team T-FORCE VULCAN Z 16 GB (2 x 8 GB) DDR4-3000 Memory  ($83.99 @ Newegg Canada)
Storage: Lexar NM600 480 GB M.2-2280 NVME Solid State Drive  ($57.99 @ Canada Computers)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive  ($69.50 @ Vuugo)
Video Card: Asus Radeon RX 5700 8 GB Video Card  ($429.99 @ Memory Express)
Case: Thermaltake Versa H18 MicroATX Mini Tower Case  ($54.99 @ Amazon Canada)
Power Supply: Corsair CX (2017) 550 W 80+ Bronze Certified ATX Power Supply  ($64.99 @ Canada Computers)
Total: $1008.94
Generated by PCPartPicker 2019-10-02 22:05 EDT-0400
