Hey so I ve bough a new graphics card XFX rx 580 4gb like a week ago and the monitor started blinking so i ve looked everywhere and tryed v sync which kinda helped but it was still there time to time
i thought that it was heat problem or something like that so i installed msi afterburner and set the fan speed from 30% to 70% (idk if this would ve helped but i tryed) and when i started game the computer turned off and didnt want
to boot i tried giving it older GPU (yes i used DDU) that i changed and it worked perfectly so i thought maybe it was PSU and i already had 600w so i gave it 650w which should be more than enough
then i tried upgrading bios nothing, then reseting bios nothing i dont know what to do next.
Specs:
Windows 10 Pro 64bit
XFX rx 580 4gb
Motherboard H87-HD3
DDR3 16gb 1866mhz
Intel I5 4570
SSD 500gb samsung
HDD 1tb
Nothing is overclocked.
https://linustechtips.com/topic/1109937-pc-not-booting-because-of-graphics-card/
