Need Suggestions for Portable Mech Keyboard
rev_dude
Hello LTT community!
I am looking for a portable keyboard to use instead of a laptop keyboard and I thought I would put it out to people who know a lot more than amazon's search algorithm.
Requirements
TKL or 70/75%
Cherry MX Brown, Gateron Brown, or other quality tactile switch
As standard a layout as possible
Not super expensive
Wireless or detachable cable
Nice To have
Volume wheel
Media Keys(dedicated or in a layer)
Macro Functionality
Fully Reprogrammable
Smaller footprint
Usb Passthrough
Im guessing not all of these things exist in a keyboard under a bajillion dollars but so far I've found a few options:
Velocifire TKL71WS
    + Basically the size im looking for
    + Cheap
    - no idea what cheap cherry clone they are using  Uses Content switches, which I cant find much info about.
Keychron K2
    +Media Keys & function row
    +Big battery
    -Non standard shift
    -more expensive
    -can only find it in gateron red or blue
I am also not against building a keyboard if it makes sense.
If anyone has any suggestions feel free to share them. Thanks in advance!
Lineage - My First PC Build and Mod
Check it out on pcpartpicker.     1700x | Evga 780Ti | Modded Lian-li Lancool One Digital
PSU Tier List | PSU Calculator | 80+ Guide | Graphics card (cooling) tier list | Motherboard Tier List | Linux Guide | Before troubleshoot | Mark Solved | Community standards
i can recommend a drevo calibur/massdrop kc71, but it's a 65% and the drevo only comes with outemu switches
If you wanted a smaller footprint, you could look into any of the boards that uses low profile kalih choc switches, like the Hexgears X1
Main Rig | Personal Build | Windows 10 | R7 2700x 3.7~4.3ghz | ASUS ROG Strix B450-I | 16gb DDR4 3200mhz | GTX 1080 FE | Coolermaster Elite 130 | Corsair H60 | WD Blue SN500 500GB NVMe SSD + 1tb WD Green HDD + 1tb WD Blue HDD
Laptop | HP m6-w102dx | Windows 10 | i7-5500u 2.4~3.0ghz | 8gb DDR3L | GT 930m 2gb| 120gb Sandisk SSD
Phone | Pixel 3 | Verizon | 64gb
6 hours ago, geo3 said:
I like how Canvas looks, not how XDA feels. Would prefer SA or MT3 versions of Canvas. XDA is too light. Weighty keycaps feel and sound nicer.
yeah im in the same boat. hopefully Canvas will come to Kat or SA
