I want to upgrade my Corsair Glaive mouse because i would like to have a wireless one and it should be a bit lighter. (I play with a low dpi)
Should I buy the G pro wireless or the g703 lightspeed because I only heard positive things about them.
What would you suggest me ?
https://linustechtips.com/topic/1108925-logitech-g-pro-wireless-or-g703/
Gpro is better in every way.
but I personally prefer g703 for the little extra rgb and shape but personal preference.
10 hours ago, -Kriss- said:
Definatley g pro over the 703. 80 grams vs 107.
What griptype do you use and do you have large hands? (Like 20 cm+)
This!
The GPW is obviously lighter than the G703, while GPW is suitable for either claw/fingertip grip & palm grip, the G703 forces you to palm grip because its hump is slightly higher towards the rear than the GPW which has gradual slope lower towards the rear.
While GPW is lighter and ambidextrous and suitable for claw and palm grip, the G703 is right handed ergonomy and for me personally, the G703 is more comfortable than GPW and I use palm grip because it's makes my arm more relax than claw/fingertip grip style which forces us to contract our finger muscles to claw, with palm grip my whole arm rests on the mouse without contracting any muscles. Palm grip is less stress for me.
If you dont palm grip, then you need to get used to G703 because of that rear hump, and I mean it.
Battery wise the GPW is more superior than the G703, while G703 lasts for 5-7 days in a single full charge for 5-6 hours intens gaming per day with depends on lighting on/off.
Both are great, GPW is more versatile in ergonomy, a premium price for premium quality and tech inside it especially the battery and sensor even the sensor doesn't matter much for gaming mice these days but its sensor has less power consumption that's why GPW battery life last longer, while G703 is more specialized for palm and right handed user.
Both are for hand size between M-L I would say..
SILVER GLINT
CPU: AMD Ryzen 7 3700X || Motherboard: Gigabyte X570 I Aorus Pro WiFi || Memory: G.Skill Trident Z Neo 3600 MHz || GPU: Sapphire Radeon RX 5700 XT || Storage: Intel 660P Series || PSU: Corsair SF600 Platinum || Case: Phanteks Evolv Shift TG Modded || Cooling: EKWB ZMT Tubing, Velocity Strike RGB, Vector RX 5700 +XT Special Edition, EK-Quantum Kinetic FLT 120 DDC, and EK Fittings || Fans: Noctua NF-F12 (2x), NF-A14, NF-A12x15
