Sound distortion with 290X Crossfire
By
JR1911
in Graphics Cards
in Graphics Cards
Solved by JR1911,
Okay, problem solved . It seems that disabling Vsync DOES solve the problem, but simply disabling it from CCC isn't enough, you have to disable it in the game config files also. After a quick test both Witcher 2 and Mass Effect 3 work fine with Vsync forced off.
Meaker ·
Posted in Graphics Cards3 -
7
Harflite ·
Posted in CPUs, Motherboards, and Memory5 -
kacper6768 ·
Posted in Programs, Apps and Websites2 -
ID0 ·
Posted in General Discussion4
play_circle_filled
Latest From ShortCircuit:
The World's Fastest CPU (Technically...) - Intel i9-14900KS
