EKWB Pump Speed for 24/7 Recommendations
Go to solution Solved by Blai5e,
1 hour ago, TheNaitsyrk said:
I'm running 2x Revo D5 pumps and I was just wondering what speed should I set it up to? 50%? For 24/7 operation that is.
Revo D5 PWM pump here but my hours are not quite 24/7, maybe 18/7 - I run mine at 60% but I used to run it at 50% (albeit, I benchmark using 100%). The reason I changed was because I added a Phanteks distribution plate recently that changed my loop configuration and puts my CPU (9900k) in parallel with my video cards (2 x 1080TI's) that are also in parallel. My thinking is basically to push more fluid through the blocks as I've reducing the throughput to my blocks by running in parallel (nothing scientific just a gut feel). So far, so good - the temperatures actually appear to have dropped a degree or two but that might be due to ambient temperature and a new application of Thermal Grizzly Kryonaut on the CPU (I rotated the water block for easier routing to the distro plate).
Main PC:
CPU: Intel Core i9 14900KS SP 109 (125P-79E) (6.1Ghz P-Cores 4.8Ghz E-cores) MC SP 88
CPU Voltage: LLC6 1.43V (real voltage 1.305V + - Temps 77-80 P-Cores, 66-68 E-cores)
Cooled by: Supercool Direct Die 14th gen full nickel
Motherboard: Z790 ASUS Maximus Apex Encore
RAM: GSkill TridentZ 2x24GB DDR5 8600Mhz CL38 (OC from 8000Mhz CL40)
GPU: RTX MSI 4090 Suprim X with EKWB waterblock
Case: My own case fabricated out of aluminium and wood
Storage: 4x 2TB Sarbent Rocket Plus Gen 4.0 NVMe, 1x External 2TB Seagate Barracuda (Backup)
WiFi: BE202 WiFi 7 Tri-Band card module
PSU: Corsair AX1600i with custom black and red cables with 2x Corsair 5V+ Load Balancer
Display: Samsung Oddysey G9 240Hz Ver. 5120x1440 with G-Sync and Freesync Premium Pro 1008 Firmware Ver, and 1x Electriq USB C 1080p 15'8 inch IPS portable display for temperature and stats, MSI 23'8 144Hz G-Sync
Fan Controllers:  6x AquaComputer Octo with 5 temperature sensors
Cooling: Three Custom Loops:
1st Loop: 5x 480mm XE CoolStream radiators with 1x Revo D5 RGB pump and 1x Rajintek Antila D5 Evo RGB pump for GPU only cooling with 2x Koolance QDC3, red coolant
2nd Loop: 5x 480mm XE CoolStream radiators with 1x Revo D5 RGB pump and 1x Rajintek Antila D5 Evo RGB pump for CPU only cooling with 2x Koolance QDC3, purple coolant
3rd Loop: 1x 240mm PE CoolStream radiator with 1x EKWB Revo D5 pump (RAM ONLY)
Total: 5x pumps and 13x radiators 50x 3000RPM Noctua Industrial fans
Keyboard: Razer BlackWidow V3 RGB - Green switches
Sound: Logitech Z680 5.1 THX Certified 505W Speakers
Mouse: Razer Basilisk Ultimate Wireless with charging dock
Piano: Yamaha P155
Phone: Oppo Find X5 Pro
Camera: Logitech Brio Pro 4K
VR: Oculus Rift S
External SSD: 256GB Overclocking OS
LaptopMSI Titan GT77HX V13RTX 4090 175W, i9 13980HX OC: P-Cores 5.8Ghz 3 cores and 5.2Ghz 5 cores and E-Cores 4.3Ghz, 192GB of RAM @5600Mhz @3600 (chipset limit),
12TB (3x4TB) of NVMe, 17'3 inch 4K 144Hz MiniLED screen, 4x 17'3 ASUS portable USB-C Monitors 240Hz, Creative Sound Blaster G6 Sound Card, Portable 16TB NVMe in TB4 enclosures (8x2TB), Razer Basilisk Ultimate Wireless with charging dock gaming mouse, Keychron K3 gaming keyboard with blue switches low profile, Logitech Brio 4K Webcam.
Hand held: ROG Ally with XG Mobile RTX 3080 with Keychron K3 low profile keyboard (Blue Switches) and Razer Hyperspeed V3 mouse and 4TB NVMe upgrade (WDBlack SN850X), with 100W 20000Mah power bank and portable monitor ROG XG17AHP 17'3 inch 240Hz with built in battery, and 518Wh Power station for Camping.
HTPC: 13900KS SP111 5.9Ghz P-Core 4.8Ghz E-Core 1.43V LLC7 (Real Voltage 1.4V) with Supercool Direct Die, RTX 3090 ASUS Strix White with Active Water Block, ASUS Strix Z790-F Motherboard, 2x16GB DDR5 8000Mhz running 7600Mhz CL38, 4x 2TB Samsung 990 Pro NVMes, 3x 360mm EKWB PE White rads 3x 480mm external XE EKWB rads with 2x D5 pumps (single loop) with 21 Uni fans, G5 Odyssey 144Hz 1440p monitor, Keychron K3 slim mechanical keyboard and Basilisk Ultimate mouse, Corsair Elite Wireless headset.
https://linustechtips.com/topic/1108760-ekwb-pump-speed-for-247-recommendations/
I run mine at 5/5 all the time ,, have done sincei  got it years back.
They can run max speed all the time, they are rated for it.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
What do you mean 5/5? I don't understand.
Main PC:
Piano: Yamaha P155
VR: Oculus Rift S
My D5 is a Vario version, has a dial at the bottom for speed, doesnt use a header. 5/5 is max speed.
Makes 0 sense to me but ok.
Main PC:
Piano: Yamaha P155
VR: Oculus Rift S
He means he is running it at max speed (5/5), lowest speed being 1/5.
Main PC CPU: 7700K, MOBO: Asus Strix, GPU: Aorus Extreme 3080, PSU: EVGA Supernova G2 750, RAM: Corsair Vengeance 16GB Storage: 970 Evo 1tb
Lounge PC CPU: 4790K MOBO: Asus Hero VII GPU: EVGA 3060 Ti PSU: Corsair RM650 RAM: Kingston HyperX 16gb Storage: 970 Evo 1TB
Why not just use %? So much easier. I decided to run it at 50% speed 24/7 as according to other forums.
Main PC:
Piano: Yamaha P155
VR: Oculus Rift S
Thank you. Finally a proper answer. Best answer well deserved.
I stuck them to 50% as well. Pump goes straight into the GPUs so I suppose 50% is perfect.
Thank you a lot!
Main PC:
Piano: Yamaha P155
VR: Oculus Rift S
Thank you a lot!
those pumps are rated for 100% operation 24/7. they are cooled by the liquid flowing through them, so you can literally run them at 100% for years.
which is actually what @SolarNova was saying.
just put them to a RPM that gives good flow through your blocks, and let them run. they will run just fine whatever the speed.
