CPU stuck in turboboost
Go to solution Solved by Jurrunio,
10 minutes ago, Nine Tailed Fox said:
I believe I have performance plan enabled
run balanced then
you disabled C-states? Or running high performance power plan in Windows?
Desktop benching:
2 minutes ago, Nine Tailed Fox said:
How do I make it so it boosts when under load? Stock speed is 2.8ghz but staying at a constant 3.79. Changed something in the bios but forgot what setting it was... cpu: i5-8400 mobo: asus z370
download throttle stop, enable speedshift, go into the tpl settings and set speedshift from 1 to 225. does it get hot or anything?
cooler: nh-u9s tim: ic graphite thermal pad   "idles" 30-40~c
im assuming you've checked task manager for any background programs eating up speed, if not do it. and if it wouldnt be much of a time constraint the best option would be to reset the bios options and put everything back except for whatever caused the constant high clock. and why are you worried that its always at the high clock if you have the cooling the maintain it?
2%~ cpu usage when PC isn't doing anything and don't like it sitting at higher clock for power saving and cpu longevity
run balanced then
Desktop benching:
If balanced power plan doesn't do it, check if mukticore enchantment is enabled somewhere in the BIOS.
Builds:
