So I built my PC a while back, right now I have 4690k and of course DDR3 RAM. When I build it, DDR4 had just come out, and 1000 series were impossible to get a hold of. I eventually got my hands on 1070 after years of my placeholder 750ti.
But with the next gen consoles around the corner, I have no doubt that PC games/ console ports will take advantage of newer hardware. I am fine lowering settings to conform to my GPU. But what I'm worried about is my 4690k, and to a lesser extent, my RAM. Right now I have used my MOBO's built in overclock for a modest over clock and games run fine.
Will my CPU be able to handle the next gen of games? Or is time to upgrade?
Thanks ahead of time :)
https://linustechtips.com/topic/1108446-how-long-is-my-4690k-going-to-be-relevant/
Look at upgrading soon, quad cores without smt already have a rough time with many new games and it will only get worse.
Before you reply to my post, REFRESH. 99.99% chance I edited my post.
My System: i7-13700KF // Corsair iCUE H150i Elite Capellix // MSI MPG Z690 Edge Wifi // 32GB DDR5 G. SKILL RIPJAWS S5 6000 CL32 // Nvidia RTX 4070 Super FE // Corsair 5000D Airflow // Corsair SP120 RGB Pro x7 // Seasonic Focus Plus Gold 850w //1TB ADATA XPG SX8200 Pro/1TB Teamgroup MP33/2TB Seagate 7200RPM Hard Drive // Displays: LG Ultragear 32GP83B x2 // Royal Kludge RK100 // Logitech G Pro X Superlight // Sennheiser DROP PC38x
the 4790k is relevant as long as you are getting satisfactory performance in games. I would honestly still be using my 4790K now and for a while to come if I didn't get my 8086K
Primary PC:
4790k is a different situation than the 4690k, imo.
If I got the 4770k/4790k instead of that 4570 in my sig I would still be using it too.
Oh typo. Still I mean it, the 4690K is as good as it's perceived to be
Primary PC:
It is relevant as long as you are happy with your FPS. Now if you sold the cpu/mobo/ram... you could probably get most of what you need for a 3600 and motherboard... then you just need ram and you are doing much better.
