Need advice on how to handle algea in my loop
CiBi
Hey all
So i built a new watercooling loop a few weeks back (6-7) and yesterday I noticed a slymie white foam at the top of my reservoir. Can't have been there for more than a day or something now.
Upon closer inspection with a flashlight I think is see some small green dots at the darker bottom of my reservoir as well.
My conclusion is that somehow algea or some other microorganisms started growin in my loop. I don't know how they got there, all parts where brand new, i flushed the radiators as well and I filled the loop with demi water + the EK clear cryofuel concentrate or whatever its called.
Now at first I was planning on tearing down the whole loop this weekend, clean all the parts, replace the tubing and then refill it but maybe add some antifreeze as well since the EK stuff clearly doesn't do the job.
My question however is, since I kind off want to putt off all that work for a bit longer if possible, is if anyone can give me tips on how I could attempt to kill the organisms, flush the loop and then refill without tearing it down. What product should I use to attempt this? I've been reading about antifreeze and Listerine as options to kill the organisms.
My loop is primochill tubing, copper+acetal cpu block, nickel+acrylic gpu block, D5 pump with acetal top and acetal+plexi reservoir. I assume the acrylic and nickel are quite sensitive to anything that could kill the organisms am I right here?
GAMING PC CPU: AMD 3800X Motherboard: Asus STRIX X570-E GPU: GIGABYTE RTX 3080 GAMING OC RAM: 16GB G.Skill 3600MHz/CL14  PSU: Corsair RM850x Case: NZXT MESHIFY 2 XL DARK TG Cooling: EK Velocity + D5 pump + 360mm rad + 280mm rad Monitor: AOC 27" QHD 144Hz Keyboard: Corsair K70 Mouse: Razer DeathAdder Elite Audio: Bose QC35 II
WHAT MY GF INHERITED CPU: Intel i7-6700K (4.7GHz @ 1.39v) Motherboard: Asus Z170 Pro GPU: Asus GTX 1070 8GB RAM: 32GB Kingston HyperX Fury Hard Drive: WD Black NVMe SSD 512GB Power Supply: XFX PRO 550W  Cooling: Corsair H115i Case: NZXT H700 White
2 hours ago, CiBi said:
Honestly, it doesn't sound like algae or bacteria to me the way you describe it. A photo would be appreciated.
I'm currently at work, i'll get some pictures up here in an hour or 2
In the first photo you see the foam/slime
in the second photo you see the ‘green stuff’
edit: pictures are reversed
Doesn't look like algae to me. Probably a not entirely rinsed and flushed loop with some chemical residue. Especially radiators can have A LOT of gunk in them even fresh from the shelf.
Use the quote function when answering! Mark people directly if you want an answer from them!
Some more pics after dissassembly
I find some green residue, looks like it could be copper oxidizing?
second to last pic is my pump top
And in my last pic you see some white residue in the gpu block as well
Not algae for sure, the reservoir is from coolant residue because you didn't fill it all the way and so water evaporated leaving the active ingredients on the surface. The greenish gunk could be plasticizer related or from a dirty radiator.
Thx, that is good news. I’ll make sure to flush everything thoroughly and I should be good.
