What is the best cpu for stock cooler
Yeah..I wouldn't if I were you. 9700+ stock cooler is a DISASTER. Why they even paired the stock cooler with that thing baffles me.
And even though you have the intel stock cooler, you shouldn't base your purchase on it.
If you're happy with the 9700, you'll be happy with the Ryzen 5 3600. It performs nearly the same in all workloads, it comes with a free cooler that is better than that mess of a cooler, and most of all..it's significantly cheaper.
Lower end i5, i3s, Celerons, Pentiums, pretty much every Ryzen. Overall anything that isn't expected to get hot under normal loads. Which i7s and higher end i5s really aren't.
But seriously. Pick per CPU, not per cooler. You can get pretty good coolers for sub-$€£50.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
Pick the cpu first, then get a better cooler, because intel stock coolers are crap for high end chips.
CPU: Ryzen 5 5600x  | GPU: GTX 1070 FE | RAM: TridentZ 16GB 3200MHz | Motherboard: Gigabyte B450 Aorus M | PSU: EVGA 650 B3 | STORAGE: Boot drive: Crucial MX500 1TB, Secondary drive: WD Blue 1TB hdd | CASE: Phanteks P350x | OS: Windows 10 | Monitor: Main: ASUS VP249QGR 144Hz, Secondary: Dell E2014h 1600x900
7 hours ago, RainingTacco said:
For the love of god, dont ever use intel stock coolers. They are noisy and have abysmal thermal performance.Unless you dont mind noise, then i would use it in a well ventilated case if you really dont have money for a cooler.
Have you ever used a stock cooler with a modern celeron, pentium, or i3? In those cases, they can be fairly quiet.
Ive used them on I5 4670, its pretty horrible under load, like 40dB+ horrible. And the OP want that cooler for i5 9700...
