Gigabyte B450 Aorus Pro Wifi help
Solved by Mathieu9836,
I never used RAM sticks on the QVL list, never had an issue. The QVL list mean they tested this exact kit and it worked at the rated speed, but it doesnt mean that all others won't work. Get the RAM sticks you want and the motherboard you want, throw the RAM sticks on it and boot you PC, you will probably have to set XMP and clockspeed manually, and thats about it. Only thing that will happen if you buy RAM not on the QVL is support from Gigabyte if you RAM can't run at rated speed, but Gigabyte Support is useless anyway.....
Edit:I've seen rare cases where people can't get their RAM to rated speed, QVL or not. It's usually a system stability issue and sometimes even bad RAM sticks.
