So i'm planning to get an upgrade and my current budget is 750$(USD) And i need help with keeping the price down since its over budget and maybe change some things with it
https://linustechtips.com/topic/1108089-can-someone-help-me-with-an-upgrade/
you dont need to buy thermal paste
get an ssd for god sake. its 2019. make sure you buy a ssd which has dram cache. you will regret not buying a ssd.
power supply is overkill
buy cpu, ram, mobo and gpu used. it will save you a shit ton of money
  • You don't need thermal paste
  • You don't need those extra fans
  • I'd really suggest finding budget for an SSD
  • If you're on a very strict budget do what @Saksham recommended and go used
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
It's 2019 and you're using only a HDD.. Please don't!! At least get a small SSD and plug in a HDD later. Something like a 250GB MX500 should already be fine..
Trade out the HDD for an SSD, I would likely go for a CX550(M) instead of that EVGA PSU and straight up remove the thermal paste and fans (I would likely just get two Artic fans for like 7 euros a piece).
You could also look into going second hand if you really want to save some money. I see 2600(x) CPU's go for 100-120 USD/Euros online on eBay/local places.
get rid of thermal paste idk why u have that there cooler has it on.
I seriously recommend getting a ssd too like especially in 2019 you will not regret it. Idk how anyone lives without a ssd.
Maybe go for 4gb version of gpu?
if u need to really decrease price u can prob go cheaper monitor.
I already have an ssd in my laptop so i can just take that and put it in the pc and thats why i didn't put in an ssd
and i'm choosing another monitor instead of that
Ok so after everyone's response i've altered it a little so its better and its now under budget
i thoguht you said you already have a ssd? also dont forget that ssd is very small capacity so you wont be able to download any games. Your not really supposed to go over about a half of an ssd's capacity.
also that monitor is a bit too much of a downgrade i think...
2 hours ago, Herman Mcpootis said:
I have changed the gpu a little and i think that this is a perfect build now
You can get a gtx 1660 or rx 590 for the same price as the 1060.
