Hi I have 2 8gb sticks old strident z rgb 2400 memory and I want to add 2 more but they don't seem to sell the 2400 kit Any more  in my country so could I miss it up with the 3000 variant and it will just run at 2400 or should I buy 32 GB of a completely new set
2 minutes ago, oliviervbs said:
It will just downclock itself yes, but are you sure you need 32Gbs of RAM? What CPU/GPU and what do you use your PC for?
I use it for gaming Photoshop development and rendering I'm a web developer and I do alot at home so It can suck alot of ram when I'm multitasking I have a 1080  and a 8700k
