2080 + 3840x1600p. What frame rate ?
Now that Im getting the LG 38" Nano IPS 1ms 175hz 1600p I wan't to know how it performs before I pull the trigger.  What FPS would I get with things maxed out at this resolution ?  Also I want 144hz or 175hz OCed but that resolution won't give me those frame rates.  Can I DSR and find a 21:9 that will play well and is lower resolution and what not.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
https://linustechtips.com/topic/1107756-2080-3840x1600p-what-frame-rate/
It depends on the game. I think you know that.
20 minutes ago, noxdeouroboros said:
You are right, they did:
That's the 27GL850, not the one he's asking about.
Get a 2080Ti for the LG 38".
Onyx: AMD Ryzen 7 7800x3d / ASRock Taichi 7900xtx OC / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 1000 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
OnePlus Ecosystem:
Other Tech:
Easier said then done.  I would have to sell this 2080 for cheap.. then spend like 800 bucks so I can play at a resolution I don't even wanna game at.  1440p is good with me and if DSR can make a 21:9 that is about that size I will be happy.  I need 144fps gaming and 3840x1600p even on 2080Ti won't give 144fps with all AA cranked up and all settings jacked up and what not.
