Help me with my upgrade
Go to solution Solved by Vishera,
4 minutes ago, Kyou said:
If ill go ryzen 3600 for cpu how much difference will 2070super have over 5700xt?
And will both gpu hit 144hz+ in dota2 max and 60+in blackdesert medium(during war)?
Before i watched some video and says 1060 6gb can get 144hz+ in 1080p dota2 but when i bought it can only get up to 120fps at max... so i have trust issues XD
Thanks again (glad my options are good)
Yes,both GPUs will hit more than 144 FPS,those are high end cards.
The 5700 XT often matches the 2070 Super,so they are close in performance.
Hi all,
I'm planning to upgrade cpu and gpu of my current system
cpu: ryzen 5 1400
mobo: msi b350 tomahawk arctic
Gpu: 6GB Galax gtx 1060 exoc
RAM: 16gb(dual) 2666mhz vengeance
PSU: M12II Seasonic 620 watts 80plus bronze
My options are (prices in my place) 51 is to 1usd
1st ryzen5 3600 (11,500) and rx 5700xt saphire nitro (27,900)
2nd ryzen7 3700x (19,500) and rx 5700xt saphire nitro (27,900)
3rd ryzen5 3600 (11,500) and MSI rtx 2070 super gaming x trio (30,500)
or any suggestions?
r5 3600x is 13900 in my place and a rtx 2060 super is around 22,000 to 27,000 (depends on design)
My monitor is Asus MG248QR (144hz 1080p) and i have no plan to change monitor
Mostly i only play dota2, blackdesert online and will play archage unchained...
I know very little of what games need and what is the best combination so please help me T-T thanks
target budget for cpu and gpu t is 40,000 with max of 50,000
but i prefer cheaper as long as i get 144+fps in dota2 1080p and constant 60+fps in blackdesert,
also would i need to change other parts if i go with any of my planned cpu/gpu upgrade?
current system fps in dota2 is 110-120+fps(max setting) and blackdesert(60-80fps medium) and ultra low on war 40-60fps.
Thanks
https://linustechtips.com/topic/1107555-help-me-with-my-upgrade/
The Ryzen 3600 is really good and will work fine with your motherboard.
 The 5700 XT option is really good,but the RTX 2070 Super is better,choose whatever you think is better for you between them.
A PC Enthusiast since 2011
AMD Ryzen 7 5700X@4.65GHz | GIGABYTE GTX 1660 GAMING OC @ Core 2085MHz Memory 5000MHz
Cinebench R23: 15669cb | Unigine Superposition 1080p Extreme: 3566
