Is Ipad Pro 12,9" as easy to bend as ipad pro 11"
I have the last gen iPad pro 12.9 and it is bend free if that helps. There are plenty of people in my classes with the new 11" iPad Pro and they don't seem to be bent. I can't imagine why your iPad would ben if you put a case on it and don't sit on the thing.
24 minutes ago, erikvind said:
Does anyone know if the 2018 ipad pro 12.9" is just as bendable as the 11" model?
It's actually far easier to bend. The chassis has no internal reinforcement and the side holes destroy any form of structural stability left over. It's a very fragile device that has bent under two coursebooks for a colleague's son
