I use my monitor's headphone jack to get audio. If I connect a usb headset to my pc, will it still output audio?
5 minutes ago, Kilos1983 said:
I think windows can only output to one sound device at a time.
2 minutes ago, Kilos1983 said:
How do I change it so my pc outputs
Just right click it and set as default
If using the 3.5 jacks you can also often assign multiple outputs at once. My sound goes to both my speakers and my headphones at the same time. This way if I want to use headphones I just turn off the power on my speakers and don't have to plug/unplug my headphones all the time.
If you're interested in a product please download and read the manual first.
Don't forget to tag or quote in your reply if you want me to know you've answered or have another question.
