Hello, dear forum!
First time here, as i were looking to build for my college pc, working on various software (3DSMAX , solidworks, CATIA, Keyshot, sketchup,adobe suite, microsoft virtual studio). Im also doing side job taking on photo and video editing (lightroom, ps, ai, vegas,premiere)
Thus i'm just here all out asking various community about whether my build is enough for me. bear in mind that i've got budget constrain (598dollar usd to be precise)
so far, my nost valued (and on budget ) spec was :
ryzen 5 2600
ASROCK B450m pro
16GB DDR4 3000MHZ
gtx 1060 6gb
PNY SSD 240GB ssd
Aigo PSU 550W 80+ Bronze
Aigo Black tech mini/Segotep Prime M
my question is:
1. will it be sufficient for handle all the software?
2. will stock wraith amd cooler come in bundle with the cpu will be enough to handle the 'heat'?
3. does gtx1060 can be rendered well on 3dsmax? i really wanted the rx580 but i researched that 3dsmax did not play well on radeon gpu.
thank you in advance for those who replying to this!
2 hours ago, Mickey Mouse said:
1. It depends on how intense your projects are but normally yes.
2. It should, will you be overclocking?
3. In general yes.
1. ive working on the past using xeon 8 core cpu and quadro p1000 before. and it still feel very lag to me. ive worried it will be the same as ive come to believe that quadro should be the only gpu for 3dsmax.
2. i have zero to none knowledge in overclocking , despite watching LTT videos on daily basic HAHAHAHAH
3. great to heard that , thank you for replying !
