Hello everyone and thanks in advance for stopping by this thread. I am in the process of buying a new monitor since i want to experience 144fps and a better quality overall in my games.
It anyone is interested to know, i am from Argentina, maybe this clarifies some things about prices listed here.
PC specs:
-CPU: Ryzen 7 3700x
-RAM: 16GB 3200mhz
-GPU:GTX 1060 6GB
-Screen: Samsung Smart TV 40" 4K Display
I am well aware that a giant tv is not the best for gaming, since i am mainly playing LoL(1080p) and CS:GO (1024x768 i think). Basically i want to play the same games but at a much higher refresh rate to try to improve in those games. I have heard that the high fps can help a lot, specially in CS:GO.
I will not sell the TV to rise my budget, that is important.
My first option is the Asus VG248QZ 144hz 1ms GTG 1080p monitor, i can get it for 400U$D (yes, it is expensive, every piece of hardware is where i live). I read plenty of reviews and there are mixed opinions about this monitor and i would like some more if you have. I would buy this monitor at a local shop with warranty and all.
My second option is the Acer KG271 Cbmidpx 27" Full HD 1920x1080 144Hz 1ms but there are some things to consider, such as the provider. I would buy this monitor directly from NewEgg for 400U$D also but the problem is, that if the monitor has any problem at all, i would have to ship it back to USA and that is pretty expensive.
I can get any monitor from NewEgg considering it's price, so if you have a better recommendation feel free to leave it in a comment down below please. You couldn't know it's final price but if it is as cheap as 170U$D i can give it a look.
Thank you all very much again, and pardon me for my english if there is any typo.
https://linustechtips.com/topic/1107208-what-144hz-monitor-should-i-get/
6 minutes ago, jmdemj said:
Any of the displays with Free-sync should be fine
4 minutes ago, DejaVoodoo said:
Except he has a Nvidia card so make sure if you get a Freesync monitor it is compatible with Freesync.
Doesn't matter, you can just enable free-sync/adaptive sync in the nvidia drivers, if it's "G-sync Compatible" then it will just enable by default.
