Car USB 2.0 port not detecting usb 3.0 thumb drive
3 minutes ago, KhorCS said:
Anyone has similar experience? Not sure why it's happening but I know usb 3.0 should be backwards compatible
Wrong filesystem format.
Most things still want external storage to be formatted with FAT32 or exFAT.
5 minutes ago, KhorCS said:
Good to know, can u tell me what format it should be for it to work please?
Most likely FAT32.
Do note the FAT32 File System has a 4GB file size limit. Also partitions can only be created up to 32GB in size.
Just now, Windows7ge said:
Most likely FAT32.
exFAT doesnt have the maximum disk size limit, but the device needs to be considerably newer to support it.
I haven't played with exFAT myself. Was this an iteration in-between FAT32 & NTFS?
No.  It came after NTFS.  It exists for low power/complexity devices that need disk IO.  Its also fairly platform agnostic where NTFS support outside of the MS world is pretty crap.
I would like to see Linux be able to work with NTFS partitions a little better. A little more functionality/control. Well, OP can try exFAT first since it's a better option and with any luck the car will support it. If not, FAT32 then.
