Hi, everyone. First time here. So I'm trying to upgrade a old machine right now, but I don't have much budget for this upgrade. The machine mainly uses for gaming. I want to know which parts should I go first.
Cpu:i7 4770k
Graphic card: gtx 780
16g ram
3tb hdd
250g sad
https://linustechtips.com/topic/1107059-trying-to-upgrade-a-old-machine/
Cpu:i7 4770k
16g ram
3tb hdd
250g sad
How much are you willing to spend?
Cpu:i7 4770k
16g ram
3tb hdd
250g sad
What games do you want to run? What resolution?
in your case I’d think GPU be the cheapest upgrade as going with a new cpu you’d need new board, ram too.
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
for mainly gaming I see no reason to upgrade rams, but yeah GPU upgrade is beneficial.
Cpu:i7 4770k
16g ram
3tb hdd
250g sad
I would upgrade your GPU. What resolutions are you looking for? Maybe a gtx 980 or Vega 56?
Isn’t the 4470k still DDR3? If not, disregard my comment.
It is, but still I would argue that getting a watercooling setup or a water cooler for CPU (and overclocking it) would yield better performance per buck.
He’s asking for upgrades so besides upgrading the GPU, he would need a complete upgrade going to 8/9th gen intel or going the amd route if he went for cpu upgrade.
I mean im still waiting on answer what games / resolution he wants to achieve as depending on that the advice would change
edit; don’t know too much about watercooling besides aio’s so it may well be that your options is better,  but wouldn’t a custom loop also cost quite some dosh?
On 1080p and mostly I'll just play any new game that seems fun.
I have a corsair h100i, but It cause blue screen all the time when i try to overclock the CPU.
52 minutes ago, liangwj18 said:
Asus maximus hero 7/ i7 4770k/ corsair ddr3 1330mhz 8g*2/ corsair h100i watt cooling/ Asus gtx 780
1080p monitor
Would like to spend around 600 cad to upgrade the system
pick up a 5700XT with an AIB cooler.
25 minutes ago, liangwj18 said:
I just pick up a 5700xt, but with cooler is over my budget, guess I'll run without cooler for a while
as in a 5700XT that isn't using the shitty AMD reference cooler design.
https://ca.pcpartpicker.com/product/6kdrxr/gigabyte-radeon-rx-5700-xt-8-gb-gaming-oc-video-card-gv-r57xtgaming-oc-8gd
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://www.canadacomputers.com/product_info.php?cPath=43_557_558&item_id=140332 the guy in the shop told me this one's cooling system is better then the AMD one, but wondering is this one the best option for 5700 xt.
It's not the best AIB 5700XT, is the thicc or pulse available?
57 minutes ago, liangwj18 said:
Thicc is available, but too expensive, so this one might be the best option for me.
I'd get the gigabyte gaming oc since it's a bit cheaper then.
