Hi all
I'm looking for a case, as close to what you see in this pic. The pic shows a poorly photo-shopped Modivio case- http://modivio.com/
I need something that will hold a itx motherboard, proper sfx psu - e.g. corsair sfx450  and room for cable management.
More importantly is is able to fit enough fans to keep cool- but also it doesn't have a space for a graphics card. I don't want the annoyance of having wasted space where the graphics card would go.
Any thoughts from anyone welcome.
16 minutes ago, decimusbell said:
What are you using the PC for?
5 minutes ago, decimusbell said:
Just get a NUC type machine? Like the ASrock Desk Mini with a cheap used R5 2400G, dunno if the bios supports the Ryzen 3000 CPUs without an update.
Otherwise there's these kinds of cases with Flex ATX power supplies.
https://www.newegg.com/p/14G-0047-00002
https://www.newegg.com/p/N82E16811108428
sorry all,
but i dont like either of those options
not keen on the flex psu- would much prefer the sfx unit from corsair-
nuc is way too small for me- its generally not powerful enought.
and the 2 cases are not very nice.
i dislike cube cases but of the fact they stack components rather ,badly on top of each other- used to have a shuttle pc years ago and that just overheated.
2 minutes ago, decimusbell said:
sorry all,
What is it you don't like?
What about DAN A4-SFX
3 minutes ago, UrbanFreestyle said:
Ok, what hardware will you be using? what form factor do you want and what price range are you looking at?
CPU
Intel Core i5-8600 3.1 GHz 6-Core Processor    $247.99
CPU Cooler
Noctua low profile
Motherboard
ASRock Z390M-ITX/ac Mini ITX LGA1151
Memory
Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 Memory
Storage
Samsung M2 Solid State Drive
Power Supply
Corsair SF 450W 80+ Platinum Certified Fully Modular SFX Power Supply
Most cases designed to use an SFX PSU will also be designed to use a dGPU :/
https://www.amazon.com/InWin-Chopin-Mini-ITX-stickers-Aluminum/dp/B01N091225
