Can somebody please help me with what parts I need to play games at 144fps. Max 550£
2 minutes ago, MrBossUP said:
I have a 1080p 144hz monitor i would like to play AAA games at high or ultra settings at 144fps
With new games, that's not going to happen.
Make sure to quote or tag me (@JoostinOnline) or I won't see your response!
PSU Tier List  |  The Real Reason Delidding Improves Temperatures"2K" does not mean 2560×1440
1 minute ago, MrBossUP said:
Yes
Well... can you go up a few hundred, say around 800-1000?
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
Yes
You will have to look for used parts. That's low budget for your requirements if you want new.
It should be doable maybe if you dont expect more than low/medium settings and also only in esport titles.
PCPartPicker Part List
CPU: AMD Ryzen 5 1600 3.2 GHz 6-Core Processor  (£107.00 @ Amazon UK)
Motherboard: ASRock X370M Pro4 Micro ATX AM4 Motherboard  (£60.72 @ SmartTeck.co.uk)
Memory: Corsair Vengeance LPX 8 GB (2 x 4 GB) DDR4-3000 Memory  (£44.58 @ Aria PC)
Storage: Intel 660p 512 GB M.2-2280 NVME Solid State Drive  (£52.35 @ Amazon UK)
Video Card: EVGA GeForce GTX 1660 6 GB XC BLACK GAMING Video Card  (£199.99 @ Amazon UK)
Case: GameMax Proteus ATX Mid Tower Case  (£22.55 @ CCL Computers)
Power Supply: Corsair TXM Gold 550 W 80+ Gold Certified Semi-modular ATX Power Supply  (£63.97 @ Amazon UK)
Total: £551.16
Generated by PCPartPicker 2019-09-23 07:58 BST+0100
More or less the best you can get within budget
Total: £551.16
thanks!
4 minutes ago, MrBossUP said:
thanks!
You probably gotta turn down the settings to Medium-High to get 144fps, also the 8GB RAM won't help. If I were you I'd try to spend a little more to get 2x8GB of RAM, the rest should suffice for medium-high settings
best bet on my opinion would be to up the budget to around 800 find some1 selling a prebuild system and you could probably get more bang for the buck...
Some EU input to Canadian IT :D
so what graphics do i need to achieve 144fps?
in most games ultra isnt realistically achievable at 144fps even with the best gpu right now.
a mix of high ~ custom settings is what you will get .
imo rx5700 is the sweet spot for 1080p 100+fps
As someone who just received his RTX 2060, even it won't run AAA titles at 144fps with maximum settings turned on. My GPU is paired with an i7-4790k and 24GB RAM, and I run 1440p displays. Overwatch, Minecraft, Forknife, and Rocket League all run well above 120 FPS using high-ultra settings, or drop down to between 90-120 FPS using ultra-epic settings, but AAA titles don't come close to even 120 FPS. At 1080p I don't see you achieving 144FPS in an AAA game on ultra settings, and definitely not for your budget.
Desktop: KiRaShi-Intel-2022 (i5-12600K, RTX2060) Mobile: OnePlus 5T | [REDACTED] - 50GB US + CAN Data $34/month
Laptop: Lenovo Yoga 7i (16") 82UF0015US (i7-12700H, 16GB/2TB RAM/SSD, A370M GPU) Tablet: Lenovo Tab Plus (256GB)
Camera: Canon M6 Mark II | Canon Rebel T1i (500D) | Canon SX280 Music: Spotify Premium (CIRCA '08)
Total: £551.16
Ignore the msg. Mixed 1600 with 1200
Prebuilds are always more expensive than building one on your own though. Even if its sold by a person (not commercial), he will still want to make money out of it. Unless used of course..
6 minutes ago, Envit0 said:
Ryzen especially the 1600 is terrible for high refresh rates though... I would switch it to anything like 8300 for good single core clocks :) and cheap
the 8300? a 4c/4t CPU that is known to stutter in AAA titles? and that doesnt gain much at all for some singlecore speed while sacrificing extra cores that are very important in current games?
also the 8300 isnt cheap. in fact its usually ++60$ more than the 1600. the 9400f is cheap, but you might aswell get someting with actual cores to not stutter
edit: also how is it terrible for high refreshrate gaming? the 1600 as ok singlecore performance.
sorry i meant as a used prebuilt system, mybad and look for something whats been used for a year or 2 and has close to max hardware in it for the time itl be a decent deal
57 minutes ago, Envit0 said:
Terrible as in Intel always has a slight of hand over the high refresh rates :)
while suffering with their non-ht offerings in 1% lows?
yes fps can be lower, but you dont get the stuttering and the fps loss is small enough that it doesnt matter.
