about beyerdynamic dt 990 pro !
25 minutes ago, forzaragatzi said:
wanted to ask does beyerdynamic dt 990 pro works perfectly with PS4 , does the surround sound works on ps4 ?
They are stereo headphones. No surround per se. They will plug into the into the 3.5mm slot on the bottom of the controllers and work. Certainly not what I would recommend for using with a PS4, and if you are going to use them, would definitely suggest sticking with the 32ohm model.
