2.5” SSD/HDD internal cage, not 3.5” to 2.5” to add into rack mount case
Hi everyone,
In the process of rebuilding my file server into a cleaner setup with hot swap bays. Thinking of using the Rosewill RSV-L4412 as it have 12 hot swap bay accessible and it priced to not break the bank.
The only thing the case is kissing is a decent place to mount SSD, there is always the central top rail but kinda of an hack job.
I will be using a dual Hex Core Xeon on a bit older intel S5520HC with 2 HBA SAS cards so I technically have 16 ports available. 12 hot swap 3.5” disks and 4 available ports as I will be using the server to run a few VMs as well but want to run them off SSDs disk.
What I am basically looking for is a SSD/HDD cage (2-4-6 whatever the size) that is not a 3.5” to 2.5” adapter. Been looking on different parts site and the best I could find yet was a 3.5 -> dual 2.5” bracket but that’s really not I’m looking for.
Any of you guys/gals came across such a case somewhere ?
Help will be much appreciated
Thanks!
Alex
Best I can find are some Coolermaster and Corsair 2.5" cages that are technically designed for other cases, so they wont "mount" anywhere in the rack server exactly...
https://www.cmstore.eu/case/mastercase-horizontal-ssd-cage/
https://www.corsair.com/us/en/Categories/Products/Accessories-|-Parts/PC-Components/Cases/Carbide-Series™-Air-240-SSD-Cage-with-x3-SSD-Trays/p/CC-8930323
Thanks TVwazhere, both cages look good indeed, obviously mounting will be custom for the Rosewill case but I thing the Corsair will work in that situation. Very good find thanks a bunch ?
