Can't decide between Cooler Master MH751 and Kingston Hyperx Cloudx
Go to solution Solved by Poraf,
I'd recommend the MH751, they sound better and is (usually) a bit cheaper than the Clouds, the thing with Hyper X is not their headphones aren't good, its that their headphones are only marginally better than their previous generation iterations.
I have used almost all of the headsets Hyper X has to offer, the Cloud Stingers, Core, the Cloud, Cloud II, Cloud Flights. The best I've tried out of all of them would be the Cloud Cores and the original Clouds. The MH751/2 however have better sound overall, when it comes to comfort I'd say they're about the same. If you do decide on HyperX's though, the first Clouds are what I'd recommend, the others are not worth the additional asking price.
34 minutes ago, MataM said:
Hi i can't decide between these 2 headphones. Im interesed in sound and mic quality.
Thank you
I have the hyperx cloud 2's right now and i wanna upgrade, been looking at the MH751's. They seem to be the better choice from what i've seen, haven't tried them myself though
