Motherboard Ligths up with rgb pc wont start
So yeah first things first my power supply made buzzing sound. So i replaced it and well the motherboard is ligthing up, but the issue is that when i press the power buttton i wont boot i have tried shorting the pins i took out ram. can it be the power supply who fried my motherboard?
My specs>
Amd ryzen 2600x
B-450 Gigabyte Aorus elite
16gb G.skill ram 2600mhz
gtx 960 4gb
1tb bacurrda 7200rpm Hdd
sounds more like a CPU problem to me, have you tried taking it out and looking for any bent pins? Any thermal paste on the cpu and anything in the socket?
also try using some electrical contact cleaner on the socket and CPU if reseating doesn't work. If all else fails try to get a different CPU or board to test.
If someone has helped you out on the forum don't forget to give them a reaction to say thank you!
The only true wisdom is in knowing you know nothing. - Socrates
Please put as much effort into your question as you expect me to put into answering it.
Well i how did
Bend the pins cpu? How because the rig was working for a few days and i was not touching cpu at all
7 minutes ago, Kolo said:
Well i how did
I'm not saying you have, but these are standard testing steps.
