Motherboard won't display video with newer card.
I have 2 970 pro gaming/aura motherboards, one works perfectly fine while the other the vga led lights up whenever I use my Powercolor rx 570 4g red dragon gpu with no post on the screen but works completely fine when I use an older gpu from an old computer that doesn't need power from the power supply. I am able to post if I clear the cmos and power it on using the 570 but if I shut it down and turn it back on, the vga led turns back on with no post. The cpu, ram, gpu, and power supply all work fine since I tested it out with the working motherboard.
