thermoelectric design to extend battery
Solved by WereCatf,
On 9/21/2019 at 7:33 PM, Saksham said:So, why not implement this into laptops so it can extend their battery? effectively charging it when it runs hotter.
Would this work or would it be too inefficient or add too much weight/thickness?
Generating electricity from thermal differences like that is a hugely inefficient process, you could just barely light up a single LED with the amount of power generated, but you'd add quite a bit of bulk to the laptop -- entirely not worth it.
