I have a problem after installed windows on my usb drive
Solved by Jimjamesjimothy8,
On 9/21/2019 at 7:55 AM, bloodsnapper said:I have a problem after installed windows on my usb drive lost everything on the usb on which is gone, is there a way i can get back the files on the usb before i got it installed over the files? happened when i install windows 10 to the usb drive then found out the other files were gone
When it was my first time installing windows, I used a 32gb flash drive half full of files and they were all gone afterwards. I don't know if data recovery will work, but you could try.
