You could get the 3000 kit and manually overclock it, or go with easy at the 3600mhz and tighten the timings.
"Black Out"
Dedicated Streaming Rig
This is some of the best overclocking memory for the price on the market right now. It uses Micron E-Die and can easily hit 3600MHz or even higher.
https://pcpartpicker.com/product/gLGxFT/crucial-ballistix-sport-lt-16-gb-2-x-8-gb-ddr4-3200-memory-bls2k8g4d32aesbk
Just now, ADM_Foxtrot said:
can I copy the timings of the CL 14 one?
They are both the same product though.
The CL14 will be a better bin but it won't be worth it for the price. Use the Ryzen Memory Overclocking utility and it'll give you all of the necessary timings, even sub-timings.
Is it the Ryzen Master software??
