Lian Li 011 dynamic hardline loop question
On 9/20/2019 at 9:29 PM, FuegoFett said:
If I’m running a lian li 011 dynamic with 2 360mm rads for my hardline configuration with mono block cpu cooler and gpu cooler. Would it be a bad idea to run all exhaust fans and no intake?
I wouldn't recommend it. While your airflow might be fine, a push-pull config is what you want to shoot for for optimal thermal performance in your loop. With all of your fans pushing air out and none pulling air in, you won't get as much headroom to overclock, thermal-wise. IMHO being unable to OC defeats the purpose of a custom loop, at least at the consumer level
Current PC (Second Build) : CPU: Ryzen 5 1600 (OC @3.8GHz, sometimes pushed to 4GHz) RAM: 16gb Corsair Vengeance RGB Pro DDR4-2666 (OC @2733Mhz, sometimes pushed to 2800 for testing purposes)   GPU: PowerColor Radeon RX570 8gb MOBO: ASRock B450m Pro4 SSD: Inland 120gb HDD: 1tb Seagate Barracuda PSU: Cooler Master Masterwatt 500w Lite Case: NZXT H500 OS: Arch Linux+ KDE Plasma [Desktop Environment] & Windows 10 Pro [Broken due to grub 50% of the time]
Accessories: Mouse: Alienware AW958 Elite Keyboard: Corsair K63 Wireless  Headphones: Samsung Level On Pro
Phone (waiting on arrival): Samsung Galaxy Note 9
