1. Decide what CPU you will have : Intel / AMD
2. The right motherboard for the cpu
3. How much memory you need (8, 16 or 32).
4. Do you game? if yes how much do you want to spend on a GPU?
5. How much space do you need for storage (SSD / HDD)
6. Get a 550watt Power supply
7. Get a case.
done.
1. Monitor
2. Video Card
3. CPU
4. CPU Cooler
5. Motherboard
6. RAM
7. Power Supply
8. SSD's/Hard Drives
9. Case
10. LED's/Extras
This is a weird question though, because you might want a home theater PC, in which case you'd need to center around what you can fit in a small case. You might want to do video editing and/or modeling, in which case the CPU becomes more important.
Intel i7 8700k | Asus ROG Strix Z370-I | NVidia RTX 2070 Super Reference | Corsair Vengeance Pro RGB 3600MHz x 32GB | Samsung 970 Evo 500GB NVMe | Samsung QVO 1TB SSD | Custom Loop | Corsair RMx 850w Gold | Phanteks Evolv iTX TG (modded) | Acer Predator XB1
9 minutes ago, bigmouthbob1 said:
I was just wondering, when I'm building a computer, in what order should i look for the parts in?
There is no right and wrong answer - what are you doing with the PC and how much are you willing to spend - that is usually what dictates parts choices
This is truth! Budget, budget, budget. Figure out a number, and idea at least FIRST, then focus on the steps that @SupaKomputa or others have said.
"Soli Deo Gloria"
IT Technician by trade. Computer/Network equipment enthusiast!
Gaming PC:
  • AMD Ryzen 5 2600X (Stock Core Clock)
  • XFX RX 590 FATBOY 8 GB (Stock Core Clock)
  • Asus ROG Strix B450-F Motherboard
  • Crucial Ballistix 16 GB (2x8) kit 3200 Mhz RAM
  • 512 GB Intel 660p M.2 NVMe SSD (Boot & Current Games)
  • 3 TB Toshiba HDD @ 7,200 rpm (Data)
  • 2 TB Seagate HDD @ 7,200 rpm (Backup)
  • Corsair CX650M PSU
  • NZXT S340 Elite Case
  • 24" AOC C24G1 1500r Curved Gaming Monitor 144hz 1080p
  • Turtle Beach Stealth 450 Gaming Headset
  • Corsair K63 10-Keyless Mechanical Gaming Keyboard (Cherry MX)
  • Logitech G602 Wireless Gaming Mouse, Razor Death Adder
  • Win10 Home
PC Part Picker Link
7 hours ago, NinJake said:
What @NickPickerWI said, if space is an issue do the case first. Otherwise use a website like pcpartpicker and it will help make sure all the parts you select are appropriate for the build.
Yes form factor can also decided at the beginning. Do you want a gigantic or sleeper system.
