A professional engineer assembled my PC with Ryzen 7 3700x,32gb Gskill Ram, RTX 2070 super, Gigabyte x570 motherboard. (all bought from MD computers, via store and online).
I checked 15 times before coming here, things I checked are as follows:
All connectors are connected.
Tried using 1 then 2 then 4 RAMs together, then using only 1 & 2 ram on different socket.
Connected via Graphics card to Monitor via both HDMI and DP.
And few other tweaks.
The motherboard powering, the ram is powered as the LED are glowing, the graphics card has power and running.
The prism wraith cooler fan is running and led glowing.
Yet I have no display whatsoever, There seems to be no output at all from the PC to the monitor.
The bent pin happened cause the heat sink was installed upside down at first and when trying to uninstall it, the CPU came off with it, however the pin was completely straightned and installed again (only two Bottom right pins were bent).
I took a loan to assemble this PC because I am disabled and wanted to work from home and now it does not output the display at all.
