GPU suggestions for my R5 3600 build
Go to solution Solved by BTGbullseye,
4 hours ago, Streetguru said:
If used get Vega 56 or maybe a 980ti/1070
Otherwise save up and go for an RX 5700, might be able to find an open box model on a slight discount as well.
Agreed, but a 5700 XT would be a worthwhile save since he's looking for VR performance...
Hi Guys need to decide on a GPU for my R5 3600 with B450 ATX Corsair vengeance 3200 C16 and 750W power supply in a full tower with fan coolers which seem to run everything at good temperatures. All that's missing is the GPU my budget is 300$ but my main goal is to be VR ready at high level graphics, Was really hung up on RTX 2070 second hand but its a bit expensive and not sure if its worth investing in a GPU. Especially in a time when some VR headsets don't even need to plugged to a PC anymore or even a future console (to buy in the future) that would cost as much as a decent RTX but would play maybe the bit better quality of 4K games. Please advise your opinions.
https://linustechtips.com/topic/1105940-gpu-suggestions-for-my-r5-3600-build/
8 minutes ago, Vicks29 said:
750W power supply
What unit? If it's a good power supply you can look for a decent deal on a Vega 56 or something, maybe a 1070 ti or 1080. A 1070 or 980 ti make for good VR graphics cards as well, or an R9 fury or fury X if you get a bargain price. Mind the 4GB of vram if you want 1440p gaming.
Primary PC:
CPURyzen 7 5800X with Arctic Liquid Freezer II 120mm AIO & push-pull Arctic P12 PWM fans RAM: G.Skill Ripjaws V 4x8GB 3600 16-16-16-30
PSU: Be Quiet! Pure Power 12 M 1000W GPUASRock RX 5700 XT Reference with Eiswolf GPX-Pro 240 AIO & 2x Arctic P12 PWM fans Case: Antec P5
MotherboardASRock X570M Pro4 Monitor: ASUS ROG Strix XG32VC Storage: HP EX950 1TB NVMe, Mushkin Pilot-E 1TB NVMe, 2x Constellation ES 2TB in RAID1
https://hwbot.org/submission/4497882_btgbullseye_gpupi_v3.3___32b_radeon_rx_5700_xt_13min_37sec_848ms
