Different colours on same monitor with same settings
Hi Everyone,
I own 2 BenQ XL2410T's:
- They both have the exact same Nvidia Settings
- The same monitor settings
- Same Windows Colour Profile
However 1 has a much darker blacks and much brighter blacks than the other. I can't seem to find what the problem to.
I did try take a picture of the screens but you really can't see it in pictures.
Any help would be much appreciated!
Sounds like hardware variation from sample to sample. If the difference is not big enough to be photographed, then it's within the range of normal for a TN panel. Adjust the brightness and contrast settings to match as best as you can.
