Hi everyone,
Between university and jobs I have moved from country to country a few times in the last years, and my PC gaming has been limited to laptops for the obvious reasons of portability and convenience.
I have now settled in Sweden and the plan is to stay here long-term, so I decided to get a powerful stationary build. Things have changed quite a bit since I built my last PC, so I'm posting here to get advice from the community.
  • I have a flexible budget of ~2000€ / 22000 SEK, possibly including a good monitor (I think 24-27 inches would be enough, not sure if I should consider ultra-wide or dual monitor)
  • I want to aim for 1440p at 120+ fps
  • This thing will probably sit on a desk in my living room, so it should look good - no extreme gamer aesthetics but I would consider a glass side panel with optional sober rgb lights
  • Ideally this build will be future proof, I don't expect to be playing everything at Ultra forever but it would be great if I could get good performances at 1440p in 3-5 years.
I think that's all for now. Does it look achievable?
Thanks in advance!
https://linustechtips.com/topic/1105767-first-desktop-build-in-10-years/
Primary PC:
SeaSonic FOCUS Plus Platinum 550 W 80+ Platinum Certified Fully Modular ATX Power Supply
but y tho
Primary PC:
Thanks for your input guys, this is my current list:
PCPartPicker Part List
CPU: AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor  (kr3889.00 @ Dustin Home)
CPU Cooler: NZXT Kraken X62 Rev 2 98.17 CFM Liquid CPU Cooler  (kr1549.00 @ CDON SE)
Motherboard: Gigabyte X570 AORUS ELITE ATX AM4 Motherboard  (kr2689.00 @ Dustin Home)
Storage: Intel 660p Series 2.048 TB M.2-2280 NVME Solid State Drive  (kr2522.00 @ Dustin Home)
Video Card: EVGA GeForce RTX 2080 SUPER 8 GB BLACK GAMING Video Card  (kr8999.00 @ Dustin Home)
Case: NZXT H510i ATX Mid Tower Case  (kr1368.00 @ Dustin Home)
Power Supply: Corsair RMx (2018) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  (kr1199.00 @ CDON SE)
Custom: HyperX Predator DDR4 RGB 32GB Kit 3200MHz CL16 DIMM XMP RAM Memory/Infrared Sync Technology- Black (HX432C16PB3AK2/32)
Total: kr22215.00
Generated by PCPartPicker 2019-09-24 22:36 CEST+0200
How does it look? Any red flags? I'm still undecided about the RAM. I'm thinking 2x16GB of fast 3200MHz, but I haven't found one that I really like aesthetically.
