Graphics card drawing more power than should
Solved by TheKDub,
7 minutes ago, YouSirAreADudeSir said:so if the limit is set to 100% in afterburner the card will go over that regardless?
Generally you'll have priority set for either the temperature limit or the power limit. I'm fairly certain it'll exceed whichever limit isn't priority as long as the one that is priority hasn't been reached. (So if temperatures are set to the priority, it'll keep drinking up power as long as it doesn't hit the set max temp)
Doesn't look like it's set to either (there'll be a little marker)
Either way, I wouldn't worry too much about it as long as the card isn't overheating.
