Hi all
Just wondering if anyone has any advice on how I can keep using this laptop in a portable fashion.
The screen glue has got to the point where I'm struggling to use it.
A new screen from what I can see is looking to cost £500+.
I'm not bothered about the touchscreen functionality and don't mind if it looks a bit jank.
I'm just looking to replace the screen and still keep it portable.
Can anyone help.
Thanks in advance.
https://linustechtips.com/topic/1105477-sony-vaio-duo-11-budget-screen-repair-help/
