Hello people I have one question.
My motherboard is z270x gaming k5, is it possible to have two m.2 (1 TB, CRUCIAL P1, M.2 2280, PCIe 3.0 x4 NVMe, 3D NAND, CT1000P1SSD8) on her? I want to get rid of my hdd's and ssd's and just use those two.
Thank you in advance fellas
https://linustechtips.com/topic/1105171-motherboard-and-m2-question/
16 minutes ago, VegetableStu said:
you can. (manual page 18)
just for reference, use of the top slot will disable SATA ports 4 and 5. bottom would be fine (unless you're using a SATA M.2 stick there, which would turn off SATA port 0)
Thank you, was hoping using two would be fine. Cheers :)
