PowerColor RX480 Red Devil Thermal Pads
Oi.
So as I want to change not only the paste but also the pads on my RX480 Red Devil I need to know the sizes and thickness of the original pads. Sadly I do not have the original pads to meassure.
I also tried to contact PowerColor via their support inquiry form as well as via the Facebook Chat, but got not answers for weeks now. I also tried a different e-mail-adress without any success.
Does anyone have this card and may meassure the pads for me OR does anyone know where to get information about the original pads?
Thx in advance
- AudioJoe
https://linustechtips.com/topic/1104957-powercolor-rx480-red-devil-thermal-pads/
I mean the thermal pads aren't electrically conductive so I am sure you can cut out your own and cover the power phases, Mosfets, die, etc...
Just buy a strip/square of thermal pad and cut it to size.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
I need to know the correct thickness, as if they are too thin the memory will not contact the heatsink and if they are too thick the die itself will not have proper mointing pressure anymore. I tried some random strips I had left and none of them seem to work properly.
Also I can't afford buying a bunch of different thicknesses to try out and find the correct one.
