  • Hello, just recently i built my first PC with 2x8gb corsair vengeance Lpx 2133mhz, my computer would crash at seemingly random intervals and from all my tests i have come to the conclusion that for some reason windows does not like one of my 2 ram sticks and i was wondering if there is a way to fix it because from all of my troubleshooting it seems that the ram stick itself is'nt faulty but that windows is causing it here is what i have done so far:
  • Ram stick A is the faulty one Ram stick B is the good one
  •  Aida 64 always crashes due to a hardware issue when stress testing the ram stick A, never crashes when testing Ram stick B, Crashes when testing both together
  • when Ram stick A does not have any errors when running memtest86, Ram stick B does not have any errors when running Memtest86
  •  Ram stick A and B both work perfectly fine with Linux whilst stress testing memory
  •  i also tried limiting the amount of ram used to fix the issue because Ram stick A would only crash on windows after more then 6gb was used however if i limited it to 6gb then it would happen at 4gb etc.
  •  i have also tried factory resetting windows and completely uninstalling and reinstalling all of my drivers and have made sure that everything is up to date that's why i have come here because i know its not hardware related but i cant seem to pinpoint the software issue
https://linustechtips.com/topic/1104793-faulty-corsair-lpx-2133mhz-8gb-memory-stick/
Have you put RAM stick A in another slot? Have you put RAM stick B in RAM stick A's slot? Do the results change?
Brands I wholeheartedly reccomend (though do have flawed products): Apple, Razer, Corsair, Asus, Gigabyte, bequiet!, Noctua, Fractal, GSkill (RAM only)
Wall Of Fame (Informative people/People I like): @Glenwing @DrMacintosh @Schnoz @TempestCatto @LogicalDrm @Dan Castellaneta
Useful threads:
How To Make Your Own Cloud Storage
Guide to Display Cables/Adapters
PSU Tier List (Latest)-
Main PC: See spoiler tag
Laptop: 2020 iPad Pro 12.9" with Magic Keyboard
PCPartPicker Part List: https://pcpartpicker.com/list/gKh8zN
CPU: AMD Ryzen 9 3900X 3.8 GHz 12-Core OEM/Tray Processor  (Purchased For $419.99)
Motherboard: Asus ROG Crosshair VIII Formula ATX AM4 Motherboard  (Purchased For $356.99)
Memory: G.Skill Trident Z RGB 32 GB (2 x 16 GB) DDR4-3000 Memory  (Purchased For $130.00)
Storage: Kingston Predator 240 GB M.2-2280 NVME Solid State Drive  (Purchased For $40.00)
Storage: Crucial MX300 1.05 TB 2.5" Solid State Drive  (Purchased For $100.00)
Storage: Western Digital Red 8 TB 3.5" 5400RPM Internal Hard Drive  (Purchased For $180.00)
Video Card: Gigabyte GeForce RTX 2070 8 GB WINDFORCE Video Card  (Purchased For $370.00)
Case: Fractal Design Define R6 USB-C ATX Mid Tower Case  (Purchased For $100.00)
Power Supply: Corsair RMi 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For $120.00)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  (Purchased For $75.00)
Total: $1891.98
Generated by PCPartPicker 2020-04-02 19:59 EDT-0400
身のなわたしはる果てぞ  悲しわたしはかりけるわたしは
