PC Is crashing and cant solve issue
Go to solution Solved by 5x5,
9 minutes ago, TJWH said:
@5x5 Alright ill get a new PSU and hopefully fix it. If not it gives me a reason to build a new PC
Random restarts are shutdowns are usually signs of a dead power supply
System
OS- Windows 10 64Bit
CPU- i5-4570
Motherboard- Asus Z87 pro
Ram- Kingston Hyperx Fury ddr3 8GB
GPU- 980 Ti SuperClocked
PSU-  CX600
Monitor- ROG Swift 27"
The issue seems to be only when I'm playing games that are open world like Escape From Tarcov and PubG My PC will just turn off, it will not lock up the game and crash it just powers off and reboots. Some common issues I found after some research would be overheating of the GPU and power supply fan not working.  I visually can see the fan working on the power supply and for temps I used HWiNFO and started a log and played Tarcov tell my PC shut off and temps on GPU max 60 degrees and CPU 65 degrees.  Also, I made sure to update everything I could think of
Hopefully I can fix this issue I'm kinda left clueless.
https://linustechtips.com/topic/1104659-pc-is-crashing-and-cant-solve-issue/
