how to use mic and earphone on laptop with single audio jack.
Manjit singh
i am unable to use both mic and headphone with two different 3.5 mm jack my laptop has only one 3.5 mm port i bout this mic and headphone splitter but still its not working i tested all the option on window which pops up when you plugin any audio device check out images attached please help anybody know how to do it ....thank you.
I used a USB Sound card and plugged both into that.
USB device shows up instantly, no driver, everything works as expected.
EDIT - All ranges of products like this exist.... 100s of examples over the years.
Some good, Many Bad, Research if your worried about quality.
I bought a cheap unit, works great, amplified USB sound.
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
audio is noisy with this i have similar another one
You can't say that for all of them... just yours.
Mine works well without any noise.
Was just an example of a solution is all..
give me link of that from where you bout it
I don't have it, I don't save links for everything I buy.
Do a Google Search around,"USB SOUND CARD".. these are EASY to source links for.
Chinese brands exists and no-names,.. but there are so many legit options either way with many designs.
If "Headset" doesn't work, than adapter is fucked, assuming that everything else works. Try it on your phone. If that works, then it's an issue on laptop side. Go and buy external USB sound card for ten bucks or whatever...
Purify your Windows 10/11, don't give Microsoft anything that you don't want to share.
https://drive.google.com/open?id=1ZwVs9zrM493rjD42E2Pf0YcOkaW92ZUo
Tips for folding on laptop:
Lazy man wants upgrades from the sky.
https://stats.foldingathome.org/donor/Spakes
Might be the port can only do a certain task. The picture you sent also clarifies that the jack is used to take only headphones audio so the splitter isn't going to work, Better use a sound card for that.
