Are the fans properly plugged into the board? I had a GPU that had this issue and the little plastic piece that housed the pins was broken and I had to plug it in manually
Photographer, future counselor, computer teacher.
3600X and RTX 2070 with too many storage drives to count.
On 9/14/2019 at 9:27 PM, DanG5086 said:
So I just finished my pc a few days back and it’s been working fine and now I’m hearing a revving noise from the gpu fans when they are on. The graphics card is an RTX 2070 please help
Is it constant?
Make sure nothing is hitting the fan blades.
Check whatever software like afterburner or evga x1. See if they are set to 100% or if the temps are high
