1. Budget & Location
My budget is around $4k. I'm in the US.
2. Aim
I'm going to be primarily gaming (playing anything from Cube World to NMS, Star Citizen, etc.) so I want great frames, even at 2k. I would like 4k but I don't really think its necessary for this build and from what I've read and watched, 2k gaming should be just fine. I play the occasional competitive FPS so I'm looking for great response times and no screen tearing. I like RGB and I've received some feedback on Reddit that the mismatch of RGB components/brands means I'll end up with non-synced RGB and/or multiple different pieces of software to control the LEDs.
3. Monitors
Just 1. See build plan below.
4. Peripherals
I will need to build keyboard and mouse but I can get those on my own.
5. Why are you upgrading?
First build since 2007. Build plan below! Let me know what you think. Thank you!
PCPartPicker Part List
CPU: Intel Core i9-9900K 3.6 GHz 8-Core Processor  ($493.89 @ OutletPC)
CPU Cooler: Cooler Master MasterLiquid ML360R RGB 66.7 CFM Liquid CPU Cooler  ($129.89 @ OutletPC)
Motherboard: Gigabyte Z390 AORUS MASTER ATX LGA1151 Motherboard  ($259.99 @ Amazon)
Memory: Patriot Viper RGB 16 GB (2 x 8 GB) DDR4-3600 Memory
Storage: Samsung 970 Pro 1 TB M.2-2280 NVME Solid State Drive  ($299.99 @ Amazon)
Video Card: Gigabyte GeForce RTX 2080 Ti 11 GB AORUS XTREME WATERFORCE Video Card  ($1349.99 @ Amazon)
Case: Corsair Obsidian 500D RGB SE ATX Mid Tower Case  ($279.98 @ Newegg)
Power Supply: SeaSonic FOCUS Plus Platinum 750 W 80+ Platinum Certified Fully Modular ATX Power Supply  ($146.98 @ Newegg)
Monitor: Gigabyte AORUS AD27QD-SA 27.0" 2560x1440 144 Hz Monitor  ($499.99 @ Newegg)
Total: $3460.70
Generated by PCPartPicker 2019-09-14 18:17 EDT-0400
https://linustechtips.com/topic/1104493-first-build-since-2007-planning-help/
23 minutes ago, Slurm said:
A fairly good PC doesn't cost more than $1500, you really start losing value past that. Maybe just look at the rest of your set up and upgrade some of that? Otherwise just buy some stock?
Or do a custom water cooling loop in an 011 dynamic? You'd want a reference RX 5700/XT for that.
You don't need 32GBs of RAM for gaming, and it's going to be harder or much more expensive to hit high memory clocks which can help with your fps.
Included a 1440p 120hz ultra wide.
It's also pretty pointless to get a platinum or titanium PSU, performance isn't going to change much past gold.
PCPartPicker Part List: https://pcpartpicker.com/list/LyQFJ8
CPU: AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor  ($329.00 @ Amazon)
CPU Cooler: Scythe FUMA 2 51.17 CFM CPU Cooler  ($59.99 @ Amazon)
Motherboard: Gigabyte X570 AORUS ELITE WIFI ATX AM4 Motherboard  ($209.79 @ SuperBiiz)
Memory: G.Skill Ripjaws V 16 GB (2 x 8 GB) DDR4-3600 Memory  ($87.99 @ Newegg)
Storage: Crucial MX500 1 TB M.2-2280 Solid State Drive  ($107.99 @ Amazon)
Video Card: PowerColor Radeon RX 5700 XT 8 GB Video Card  ($409.99 @ Newegg)
Case: Cooler Master MasterCase H500 ATX Mid Tower Case  ($119.99 @ Amazon)
Power Supply: Cooler Master MWE Gold 750 W 80+ Gold Certified ATX Power Supply  ($74.99 @ Amazon)
Monitor: Monoprice 138035 35.0" 3440x1440 120 Hz Monitor  ($409.99 @ Monoprice)
Total: $1809.72
Generated by PCPartPicker 2019-09-14 18:47 EDT-0400
4 minutes ago, Genwyn said:
Theres not much to really say about it, its a balanced current gen high end build with good part choices. I was trying to figure out how you managed to get any single gpu system to add up to nearly 4k usd but then noticed the monitor and drive.
My only suggestions would be that for the price of the seasonic focus line, you might as well just spend the extra 30-40$ on the prime titanium rated line.
https://www.newegg.com/seasonic-prime-ultra-titanium-ssr-750tr-750w/p/N82E16817151197
180 with a rebate if you felt like doing rebates, for a 4000$ build thats not a large price difference and gets you pretty much the best of the best as far as power supplies go.
You are going to have cooler master RGB, corsair rgb and gigabyte rgb which might not all work together. I know some stuff is inter-compatible but you will likely have out of sync lighting if you wanted anything more than static colors. Bit of proprietary bs really...
It wont be the worst and it would be nearly unnoticeable on your average "glow" type of settings where everything is kinda random colors anyway. Might be worth looking into an the corsair H150i rgb instead of the cooler master 360. Its corsairs 360mm aio and it would be compatible with the case rgb, so then you'd only have corsair and gigabytes rgb to try and sync together.
Thanks for taking the time to look it over @Genwyn. I really appreciate the suggestions and will definitely consider it. I think I will upgrade the PSU to their Titanium line. I liked the CM AIO because of the included RGB Fans and RGB pump that has the "cap" that can be rotated, for aesthetic reasons of course. I could totally switch to the Corsair AIO, but it looks like no RGB Fans (included at least). I wonder if I could swap those out for RGB fans.
CPU: AMD Ryzen 9 3900X 3.8 GHz 12-Core Processor  ($499.99 @ Best Buy)
Motherboard: Gigabyte X570 AORUS ELITE ATX AM4 Motherboard  ($199.00 @ B&H)
Total: $3405.81
Generated by PCPartPicker 2019-09-14 18:49 EDT-0400
Ryzen 3900x includes RGB Fans for FREE.
Total: $1809.72
I'm not really looking for a custom loop or an ultra wide display. Thanks for the suggestion about the RAM tho! I wasn't sure exactly how much I needed and might've went overboard with 32 GB.
Then maybe grab a 1080p 240hz display if your sole focus is gaming. They're like $250 max
$4k is a huge budget but you shouldn't be wasting it going overboard on most of the things. Here are my thoughts about this
1. Will get an ASUS Motherboard, much better firmware.
2. You won't benefit from the more expensive 3600MHz cas 16 kit if only gaming is your concern and the very narrow difference that it makes isn't noticeable in real world performance. Also 16GB is more than enough for gaming.
3. 970 Pro is a waste of money. For Gaming only the Sabrent Rocket is just as fast with similar load times in games and cost 1/3rd the price. The 970 Pro is more of a thing for professional video editors who need real fast storage and tend to work with huge file sizes.
4. Spending $350 on the same card just to get the wated cooled one isn't a wise idea. Also you sure you wan't dual rads in your build??
5. A very similar looking case the 570X RGB is $90 cheap.
6. 650W Gold Certified Corsair RMx is more than enough.
7. Can spend $120 more on the Monitor and get something that has G-Sync.
All that said, here is a recommended build
CPU Cooler: NZXT Kraken X62 Rev 2 98.17 CFM Liquid CPU Cooler  ($140.89 @ OutletPC)
Motherboard: Asus ROG STRIX Z390-E GAMING ATX LGA1151 Motherboard  ($229.99 @ Best Buy)
Memory: G.Skill Trident Z RGB 16 GB (2 x 8 GB) DDR4-3200 Memory  ($99.99 @ Newegg)
Storage: Sabrent Rocket 1 TB M.2-2280 NVME Solid State Drive  ($109.98 @ Amazon)
Video Card: Zotac GeForce RTX 2080 Ti 11 GB AMP MAXX Video Card  ($999.99 @ Newegg)
Case: Corsair Crystal 570X RGB ATX Mid Tower Case  ($189.97 @ Newegg)
Power Supply: Corsair RMx (2018) 650 W 80+ Gold Certified Fully Modular ATX Power Supply  ($119.98 @ Newegg)
Monitor: Asus PG279Q ROG Swift 27.0" 2560x1440 165 Hz Monitor  ($617.99 @ Amazon)
Total: $3002.67
Generated by PCPartPicker 2019-09-14 20:33 EDT-0400
